Rochester, NY 13-1 dropouts HR20-100 | SatelliteGuys.US
mike1973
1,107
4
Rochester, NY
We have been having a problem with the local ABC substations, 13-1 and 13-2. Signal strength is 95+ and it seems to drop every minute, just get a pixelization and audio drop out. All other channels (most with lower signals) work fine. Any thoughts?
Mike,
I have the same problem on my 622 but with the new software it is a little more stable, although it still dropos out. 100 signal strength here.
Well, at least its not me! Seemed to be much better on my 622 but we're not using that for OTA right now, might have to switch back. Just seems odd since that and Fox are the strongest signals I get, 95-100 all the time. Guess I tweak my antenna a bit and see if I can defeat the mutipath!
Home user
Problems With Box.....???
