Any body else having problem with their RokuTv Volume mine is very low i have to turn my tv all the way up to hear it. Just started Sunday.
Is this a problem for all video sources (TV tuner, cable box, DVD/Blu-ray, etc.)Any body else having problem with their RokuTv Volume mine is very low i have to turn my tv all the way up to hear it. Just started Sunday.
TV tuner and all Roku contents Dish is okIs this a problem for all video sources (TV tuner, cable box, DVD/Blu-ray, etc.)
Yes does not helpDoes your roku remote have a volume button on it?...
What is the specific make and model of the Roku TV (there are dozens).TV tuner and all Roku contents Dish is ok
Plug the Roku into a different input on the TV to see if the trouble follows( I assume other devices don't have the same issue).... Roku does have audio settings that might be messed up..I have mine set to auto.....one big one under accessibility...there is a volume setting that can be set low, medium or highYes does not help
This is a Roku TV, not a standalone streaming device.Plug the Roku into a different input on the TV to see if the trouble follows...
Should have similar audio controlsThis is a Roku TV, not a standalone streaming device.
It is a Hisense 65" R6 connect to a vivio sound bar it has worked great for 6 months till sunday volume leveling is onWhat is the specific make and model of the Roku TV (there are dozens).
I believe the TVs have a maximum volume setting. Has anyone been tinkering recently in the audio settings of the TV?
There is also a volume leveling feature that may be doing some bad things.
EDIT: Is there some sort of sound system outside of the TV speakers in play?
Please use complete sentences in your posts.
optical cable, TV's volume when not connected to the sound bar is the same real lowHow are you connecting the TV to the Vizio sound bar?
Some have reported relief from changing to a different connection type (i.e. optical cable .vs. HDMI ARC).
How is the TV's volume when not connected to the sound bar?
Check the volume control under accessibility in the menuoptical cable, TV's volume when not connected to the sound bar is the same real low
Only in Juan's mind. The Hisense R6 is most certainly a Roku TV.At the start of this thread, it was a Roku TV, now its not.
Umm it has Roku controls built in correct?.. so the menu would have similar options to a Roku for soundbars and suchOnly in Juan's mind. The Hisense R6 is most certainly a Roku TV.
Hence the "R"6Only in Juan's mind. The Hisense R6 is most certainly a Roku TV.
A roku is a roku...hisense just has it built into the tv...it has the same options as a stand alone roku...not sure why Google didn't tell you thatOnly in Juan's mind. The Hisense R6 is most certainly a Roku TV.
Limited time offer
