P plee33 Member Original poster May 27, 2006 14 0 Jun 2, 2006 #1 Almost everytime that I turn on the receiver the screen just rolls vertically. It looks like the vertical adjustment is off. Anyone know how to fix this?
spindoctor SatelliteGuys Pro Jun 5, 2005 174 0 Jun 2, 2006 #2 it sounds like you are on pal mode see if you it has a switch on remote to go ntsc, if not it has to be done on the menu every receiver is different.
P plee33 Member Original poster May 27, 2006 14 0 Jun 9, 2006 #3 Actually, it was in "Auto" mode. I changed it to NTSC and now it works fine. Thanks.
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,262 14,512 Mankato, MN Jun 9, 2006 #4 cool. Glad you got it fixed
rainmaker SatelliteGuys Pro Apr 26, 2006 296 0 Louisa KY Jun 10, 2006 #5 FYI. another way to fix this is with a black&white tv will allow you to see the menu so you can reset.
