rotor reset | SatelliteGuys.US
rotor reset
bigmudge
19
I scanned before I found true south. My rotor is not on 0. How do I reset it?
On the receiver settings is Disc1.0-none
Rotor-user
What receiver and motor are you using?
I have a Pansat 2500A and I usually manually move the motor back to zero, then unplug and replug my receiver. This normally corrects my problem. You can also try selecting "Reference Position", this should also move the motor back to zero.
I have a vs2000. I did what you said and found a motor menu it went back to zero.
Diseqc 4x1 switch and how does it work
Problem Receiving Some Equity Stations on G10R/Ku
