RT on 97W low audio | SatelliteGuys.US
RT on 97W low audio
Cham
VE4GLS
2,566
1,142
Boonies
Noticed RT and AJZ both using digital dolby audio lately on the 97W broadcasts. AJZ seems ok but RT audio is very low on both the Micro and AzBox. Kind of annoying when switching between channels. Is anyone else noticing this?
-C.
I've heard the audio also completely cut out over the last, at least, 4-5 days. Annoying. Maybe a techs fingers on the wrong 'pad' in prep for HD?? Nah, it's happening 24/7.
I have the same problems on my setup to KTV channels just blow you away while the rt audio goes out and comes back. every since they went to HD that problem has been going on.
Dan Rose
Yes KTV2 certainly the opposite issue. Possibly discussing it here someone will take note and make some adjustments. I would think it to be ok to contact them also, they might appreciate the signal reports.
bsc621-2 woes
HVEC (H.265) Thoughts.
