RTPI AMC4/KU major problem | SatelliteGuys.US
RtpiFan
236
6
Montreal,Quebec,Canada
Look like Rtpi is up to it's old trick's again sound olny since 17h30 EST.
It's now 21h22 EST their still having issues must be 12169H RTPI only everthing else is okay.
Update:22h00 EST TP is back and RTPi running fine again.
RtpiFan :)
Hi RTPFAN,
Is RTPI on AMC4 101W still up? I was tring to get it yesterday and was not able to.
Thanks,
Virgil
Slightly related:
For whatever reason, Lyngsat has removed the RDP radio channel on the same transponder as RTP on AMC4. Don't worry, it's still there - even if it is selected as a 2nd audio channel on some systems.
DiscoLoveGrapes said:
Slightly related:
After RTPi's outage on 26/01/2006 RDP was not being broadcast on the second audio channel for few days to a week.
Lyngsat updated list of content for 12169H=AMC4 on Jan 30 at that time RDP was still not avaible and could be the reason why the removed the listing and they still have not noticed it's back.
RtpiFan :)
4/03/2006 outage
Hi,
Could someone please check if AMC4/KU 101W Freq:12169 H SR 3.003 as signal/quality on all other TP's are okay.
Look like an other outage.
RtpiFan :)
55% signal quality on the Traxis 3500
The other TP's are around 75% Signal quality.......
79% quality with a 71/2 mash dish C-KU International feed CalAM LNBs and Traxis 3500 receiver
They where out for short time when had posted they had being out for about 5-10minutes.
Average for me is around 72-75% on 76cm and on 1M it's alway at 89-90% regardless of wheater had moved the AMC4 on 1M to watched little news and then after bit got the old no signal so went upstair to the old office/media room where moved over to AMC4 on 76cm and was getting evrything except RTPi @ 12169H.
RtpiFan :)
Need Help Slaving FTA To 4DTV
This is what I don't understand....
