Title says it all. The slot for REVN has been replaced by another channel, and RTVE's slot no longer scans in.
At least the channels are available FTA on other satellites.
C-band satellites, which doesn't mean much to those of us that only have Ku.
Must of just went off the air today. They were there yesterday.
That is a good question. I read something about this and need to keep track of it. ThanksThen all the various C band feeds will drop on July 1 and consolidate or remain on 83 W???
At least the channels are available FTA on other satellites. Always seemed strange that Luken duplicates channels and custom feeds for each market. Inefficiencies in distribution is a significant and unnecessary burden for a company that has repeated financial problems. Would make so much more sense to uplink generic time zone feeds, a syndicated blackout feed and do local insert at the downlink.
How is the signal strength on 83W compared to 87 W?Yes this is correct .. they are in the process of switching from 87 W to 83 W. July 1st the mux on 87 W will go dark.
I moved over to 83W and found it a little stronger. See how it goes.
Thanks for the info.
Limited time offer
