I noticed my installer did not put rubber boots over the connectors at the grounding block. It does look like he used weather-proof connectors though. Is this a big deal? Is it worth redoing the connectors to put some boots on? Just curious...
StevenD said:Do a search...there has been plenty of discussion of this topic. I tend to think they they actually hold IN the water.
birddoggy said:i agree with all the previous posts, also, if you decided to put boots on, you'd have to cut the connectors off, put the boots on, then put new connectors on... and unless you have the tools to put on compression connectors, it would not be worth it anyway.
compression connectors last a long time in the weather unless it has a bad seal inside. (before i get any bashing... i know, i know, its not a good idea, and i would never do it at a customers house) but, at my house i actually have 2 connectors barrel connected together buried... has been there for about 3 years and have never had a problem out of it. (ps: not recommended)![]()
OoTLink said:When I first saw the name of this thread I thought you were worried about having to wear rubber boots to put up a dish!![]()
When I worked in cable I was told the dieletric grease weakens the ground...especially those who fill the connector and then connect it onto the port. I never saw it cause a problem, but we were given a teflon compound to put onto the threads of the port only, then screw the connector on.inwo said:Ditto. Boots makes things worse.
Why all the objections to silicon dielectric grease? I would never do an outdoor connection dry. Nothing is easier. KISS!
Hor vert underwater it doesn't matter. Water will get in to anything one way or another, if there is room for it.
The next best thing from silicon fill is "nothing". A loose unsealed connector lets the moisture out.
IMO
Limited time offer
