rv'ing and having troubles | SatelliteGuys.US
tadpole
4
I've taken a RCA Directv receiver (mn 7m09-obtained from back of receiver)
from my home. At home(zip 77318), I have an round dish with single lnb. The dish I obtained for the RV is oval - "triplefeed, Multi Satellite LNB". I can't seem to get it installed to get reception.
Just wondering if these components are compatible? Or if I have failed to get it
properly pointed at the big birds.
Tks,,
Tadpole
Menu - yes,we checked menu and it offers oval with 3 lnbs.
Receiver - 4 to 5 years old
There are four coax connections on the LNB, does it matter which one
that I connect to?
that I connect to?
No it doesn't matter which one you connect to, in your situation.
Did you try setting it up for the 3 lnb set up ?
That is where I would look first, provided your coax and all other connections are made properly.
If everything looks correct, it's probably an alignment issue, keep trying...
You did put in the current zip code to get the correct settings , right ???
Jimbo
10-4 Jimbo,
All areas are as you suggest. I agree, it must be alignment situation.
tks,,, tadpole
You can Get OTA for HR20 tonight!!!
HR20 RF Remote?
