According to the owners manual for the 30FS4D, the TV/VIDEO button is used to toggle from Antenna, Cable, Video1, Video2, Front video, Component, & HDMI/DVI. If you used the S-Video on the back of the TV, it should be Video 1. You will also need to hookup some audio cables (red/white) from the receiver to the tv (input 1 L/R) for the sound.sethm said:Great, what is the proper connection set up?
I went from the Sat box to the back of my TV, but from there not sure what is next. Seems the only input feed option per my tv (LG 30FS4D) is :
TV, CATV, DTV and a 4th option.
The S-video seems to be just that a "video" input/output. So why does the back of the Sat box have a S-video connection if can't be used to send the Sat signal to the TV.
Seems like some people don't have the intelligence to deserve good TV. I thought the instructions to plug the "S"video cable into the TV were quite simple, nothing was stated about plugging a "S" video into a vcr.sethm said:Just got home-
bummer my VCR does not have an S-Video, so it won't work.
(from Sat Box, cable to VCR in, the VCR out to TV in).
If your satellite receiver has 2 sets of output connections, just do the following:sethm said:Just got home-
Limited time offer
