Hello has anyone been able to find or scan any SX2 Transponders on the North American satellite?
it's an extension of DVB-S2 that adds some technical capabilitiesWhat is SX2?
You will have too check whats available at your side of the pond, as long has you have the correct receiver/TV its not a problem,
This is from 33E here in the UK from my LG TV.
It is born out of not being economically feasible to install cable or fiber in cities that are hundreds of years old.You guy's have the best FTA -
It seems likely that none exist as Brct203 noted so you're probably banging your head against the wall in vain.Well I am looking for some for America Satellites I am having a hard time locating them..
DBS-S2X is a EU standard (European Telecommunications Standards Institute) so it doesn't follow that the US would be quick to adopt it. Things may change if the standard is adopted by the ITU.
Being the season of politics, I'm convinced that almost everything I hear is fake news.I have heard that someone found a S2X data transponder on 87 W C-Band - However I do not know the details
Limited time offer
