S9 software | SatelliteGuys.US
S9 software
shankle
338
florida
Thanks for any help. I bought my S9 Openbox in 2010 and it still has the original software. Last night I mistakenly hit the V-format button and had a devil of a time getting back a signal. Is there new software for it and where would I get it? Is the new software worth the trouble and will it solve the V-format problem?
I also have old firmware, possibly the original, on both of my S9s. I don't remember the V-format issue ever being addressed by newer firmware.
I superglued the V-Format buttons on my remotes, others had other ways to "fix" that deal but I can't remember what they did.
None of the newer firmware disabled the V-Format button but newer firmware did correct:
Stuttering video and audio-video sync problems on some channels. Recordings now are in a standard format playable on a computer (without conversion). A recording timer that works(although the time needs resetting every few days). And a few others that I can't think of at the moment, but think the most visible improvement is, The Green tint (video) is gone.
Thanks guys, Next line is not working on my HP Pavilion 64-bit on this site. Guess I'll try the super glue route. Being an electronics novice, it's probably the safest way to go. I have no green tint so I'll stay with my present software
I had an RCA tv remote with a reset button that was right where you'd always hit it by accident and put everything back to factory settings,pain in the ass.Took a razor blade and shaved it off flush with the face of the remote,no more accidents.
Done that before.
Openbox S9 Record Info Needed
C/Ku Feedhorn
