Is the Safeway network still broadcasting? I haven't been able to get a signal on that transponder for a couple of days.
This Satellite is said to be "Off Center" and is about 20 degrees off. If you have a fixed dish, you can turn the lnbf slightly to help with the "Skew" and it should improve a little. If you have a skewable lnb, you can make the appropriate adjustments in the Set-up Menu's.
Or if you have plenty of time on your hands, you can walk out to the dish and skew the lnbf while you are on this Satellite. And when you watch the rest of the satellites, be sure you go back out and put the lnbf back where it was.
Al
So, with a motorized set-up tracking the belt using USALS, is it safe to assume that I will not be able to pick up good signals on AMC1? Would tweaking the set-up using Diseqc 1.2 make any difference in signal quality?
Move the dish to AMC1 then very carefully skew the LNB 20 degrees until you get a good signal.
Limited time offer
