Saginaw Reed Switch Question | SatelliteGuys.US
SatScanner
36
East USA
I have a 24" Saginaw actuator and am having problems with my new VBOX V3000. I'm getting error E2 on the box so I'm not getting sensor pulses. Sometimes it works sometimes not. I was told on the Sadoun forum that the reed sensor might be bad. I've been trying to find a replacement but no one seems to sell them. I found a reed sensor on Digikey: PN: CH410-ND
Digi-Key - CH410-ND (Manufacturer - MP200701)
I don't know what the specs are supposed to be but this is my best guess. Can anyone confirm what the electrical and mechanical (threads) specs should be?
Thanks for the reply. I took a look at Skyvision, unfortunately none of the sensors look like mine. Mine is a threaded barrel about an inch long and just under a half inch in diameter.
