Samsonic BS-8100 want to learn how to setup? | SatelliteGuys.US
Rockstarkc
KCKS
It has Antenna Setting?
SATELLITE? (has all these options, for ex.) Telstar4 C, Telstar32, Galazy2, etc...
lNB TYPE?
DISEQC PORT?
MOTOR SETTING?
22KHZ? ON/OFF?
0/12 VOLT SWITCH?
LNB POWER?
FTA ONLY?
It has also "AUTOMATIC SEARCH"
Satellite? options
FTA only?
SearchSTART?
addSymolrate?
I don't no where to start... basically, I want to watch all the free SouthEast Asian chanels for example the Persian chanels, arabic, Korean and Indian. Tell me what is the easiest way to set this up please. If you like you can email me the answer/s at: rockstarkc@hotmail.com.
Thanks, and have a great weekendall :)
Al
1. Where are you located ?
2. Do you know the satellites that carry the channels you want ?
3. Do you have a satellite dish, and what size ? What lnbf have you purchased ?
We need a lot more info than your "wishes" to give any advice. :)
The only Korean FTA station up there I am aware of is CGN, a religious station. It is on 30w and I believe 61w on Ku band.
Sent from my Timex Sinclair using SatelliteGuys
How should i prepare for a cat 1 or 2 hurricane for my dishes??
mounting block?
