Like the idea of water not being a issue.
http://www.androidcentral.com/samsung-announces-water-resistant-galaxy-s4-active
I think the camera is the only difference.
If that's the only difference, I'm god with that ....
Guess ill see what it looks like in persn before desiding ....
I have heard the buttons on the front are actual physical buttons as well.
Sent from my Samsung Epic using SatelliteGuys
The Galaxy S4 Active shares much of its internal hardware with the vanilla Galaxy S4, including a quad-core Snapdragon 600 CPU at 1.9GHz, 2GB of RAM, a 1080p (TFT, not AMOLED) display, 2600mAh battery and 16GB of internal storage, expandable via microSD. The camera's taken a minor hit, going from 13MP on the regular GS4 to 8MP on the Active.
The main difference is the "fully sealed design" that the manufacturer's boasting is certified IP67 water and dust resistant . That means the external chassis looks a lot more durable, and the capacitive keys have been replaced with three physical, clicky buttons.
Yep, the camera, the buttons, the design to "ruggedize" it, and the screen is not AMOLED (which may be a good thing). Other than that, the specs are the same.
Lcd is in some ways superior or preferred.
Limited time offer
