Samsung DSB-4700F | SatelliteGuys.US
Samsung DSB-4700F
rushelp
12
usa (tempe az)
Hello everybody.
I'm having an issue with my receiver. It doesn't turn on, after I turn it off at night. The clock doesn't show. I tried to turn off and turn it on again from the switch behind, but that doesn't work.
Any help?
Best,
Rushelp
so after flipping the switch off and on the clock doesnt go on and the unit wont power on?
If so, make sure the plugin isnt bad (the outlet)...I know...gotta start with the obvious
otherwise it could possibly be a fuse or a capacitor. I would take off the cover and look for anything that looks cooked.
It seems that there's no power at all! I tried to plug in the receiver to different outlets, but no progress. I opened the cover, and there's nothing that looked suspicious to me. Fuse that the only thing came to my mind. How do I check the fuse, if it's working or not? I'm not familiar with capacitor?
So, I bought new fuse and test it, didn't work.
I have two same recievers, so I tested the fuse on the old one, the fuse was working. I tested the cable it was working too.
Any suggestions?
what network is this?
Road Trip!
