Samsung TS-360 or RCA dtc-210? | SatelliteGuys.US
srusin1
2
Which Directv HD reciever do you advise I should get, since they are the same price(~$200). I have a 61" Hitachi RPTV without DVI so that does not matter. Which one is more reliable? Ive seen the onscreen guide for the samsung. How is the rca? Which one is quicker when going through the menu? ALso the toshiba receiver is available, any word on that.
I have both. While the receivers have a diffierent exterior, their menu systems are exactly the same. Same look, same speed, same configuration options. The 360 does allow you to select some of the options using a front panel digital display. The 210 has an RF coax output, which is nice if you have a video distribution system. Other than that, I could see no difference.
I could tell no difference in HD or SD picture quality between the systems. I haven't had them long enough to determine reliability.
view cable provider locals using receiver
phone call earlier today
