Sat 110 Reception Problem | SatelliteGuys.US
sgsterling
3
Anyone heard of this??-- installed a new 3-LNB dish to upgrade to HD. Sats 101 and 119 have good sigs, but 110 is in the 30's. If I rotate the dish (tilt) to the stops (140 degrees), the 110 transponders get up in the 50's-- like if I went 90 degrees, sigs would be where they should. Any chance the problem is polarization, LNB is installed 90 degrees out?
Do you have any subscribed to services on 110?
1. Your mast must be 100% plumb and level to continue. (NO EXCEPTION)
2. Set your location specific skew & elevation mark and leave them alone.
3. Use a heading compass to eyeball your location specific azimuth.
4. If no signal is decent, bump it and give it a few seconds to register.
5. Once signal is peaked (88+) snug it.
I would use the manual selection of 3 LNB dish setup in the receiver menu.
Your receiver can give you the correct location specific co-ords, or post your zip here to make sure the ones you have are correct.
Yes-- HBO and showtime HD are on 110 I believe, plus some others in that HD package. They are there, but full of dropouts.
National Network HD feeds (Urgent Update):
2nd receiver @ second home
