sat dish with h21? | SatelliteGuys.US
sat dish with h21?
niraj
2
Austin
I tried to search for this info but I'm not really sure if what I searched for was even accurate...
I was wondering if a phase III triple lnb will work with a h21? I know the satellites I need in my area are the 101, 110, 119 so the dish can access those but will the dish and the h21 behave together?
Thanks!
The Phase III triple LNB dish doesn't receive the 103 and 99 sats if you want HD. It will work fine if you don't want HD. Just run setup to select the correct dish.
I was under the impression that either 101, 110, or 119 had some HD feeds?
My friend runs a 3 lnb setup using a 5 lnb SL dish with an h20 and gets HD feeds. The only satellites he connects to are 101, 110, and 119. Am I missing something?
The HD feeds on 101, 110, and 119 are going away fast.
So your friend has a 5LNB dish but only uses it as a 3LNB. Most likely those 3 are 99, 101, and 103.
Streaming HD programming to TV
D12-500 is dead
