Sat finder | SatelliteGuys.US
Sat finder
fire1000
35
henderson,ky
Has anyone used them sat finders the ones with 5" screen that shows the ch playing.
Like this oneThe Satlink WS-6906
Are they ez to use. Can you just hook up to the dish and really move it back and Fourth and it tell you what sat you are on.
Easy to use. Works exactly like your satellite receiver, but without the need to carry a TV and extension cord out to the dish.
It doesn't tell you what satellite that you are aimed at. You select the LNB type, switch path, target satellite and an active transponder. The meter indicates when the dish is aimed at the selected satellite.
Satellite Launch in just a few minutes...
Scriptures for America
