Sat Radar dish | SatelliteGuys.US
Sat Radar dish
Unless someone has a horror story about that particular dish, I suspect it's an okay deal.
Seems a bit high for a 30" off-brand dish, but that LNB sweetens the pie.
You can probably search around the internet, find someone selling them new, and get a PDF manual.
Though, after looking at several similar dishes, they're pretty easy to assemble.
OEM product manufactured by Azure Shine, the same manufacturer of our GEOSATpro dishes.
Hopefully the seller still has the shipping carton .........
New Sat Radar dish is up. Not much of a change for quality on G10. Rather dissapointed. Review to come soon in the review section.
The last one was a 31 and this one is as well. I figured the bent portion of the last dish was causing signal loss so I figured a different dish would help. No change. Turns out I should upgrade the size.
Well, no harm done.
Ya learned.
I'm sure you'll learn some negative about bigger dishes, too :rolleyes:
But maybe you'll leave this one pointed at a favorite bird, or use it for a relative or neighbor and get them addicted to the FTA habit. :cool:
Sat Radar 31" dish
dish setup
