Satellite 95 no signal | SatelliteGuys.US
tbleic
2
Whitesboro ny
Hello sirs. I'm having a problem trying to configure my satellite system from a slimline 5 SWM to 18inch round and international with a Zinwell 4x4 multi switch. I get no satellite response for 95. Not even searching for satellite signal. It simply wont acquire it. 101 comes in strong with all the programming as expected. I've repeated satellite setup many times now and reset everything on the receiver but same results. Installed a new multi switch, checked the cable for continuity and it's good. I measured voltage at the 95 lnb. Not getting any volts with the receiver on. Does Directv still use 95 for international programming or does it solely come from 99 and 103 now? This worked perfectly fine just a few months ago. Any suggestions would be appreciated. Thank you, Tom.
