I always know it's about to rain because I lose signal. By the time the rain actually gets here it's usually back on. Very annoying, but I'm going to be cutting down a couple of trees that might be interfering in the next few weeks so hopefully it'll get better.
Very annoying, but I'm going to be cutting down a couple of trees that might be interfering in the next few weeks so hopefully it'll get better.I always know it's about to rain because I lose signal. By the time the rain actually gets here it's usually back on.
I have a fairly recently installed (by a very handy friend) GloryStar dish with one old and one new GloryStar receiver hooked up to the dish with a GloryStar 4 way splitter and 2 GloryStar signal boosters. Whenever we get any rain both receivers shut down - no programs until something dries out. Does anyone out there know what part of the antenna system I should put waterproofing on ?Are satellite signals affected much by storms?
Same as jadiff stated. Very seldom lost signal until upgrade to Eastern
Arc. Now it goes out much more often with storms.
Where are you located? I'm in Central Pa.
This is very frustrating! What options do I have though? I already had them back out and thye replaced the lnbf because they said the signal was fine. Maybe I'm in some kind of pocket or I should see if i can go back to 110/119 61 wing, but I don't really think that is an option.
Anyone have suggestions for those of us with these problems?
Converting from small dish to a 10' primestar dish really helps but is rather difficult to convert unless you know what you are doing.
This is the one that I'm looking at...
Limited time offer
