Satellite Locations vs Names? | SatelliteGuys.US
Lone Gunman
3,238
883
southeast
I'm sure this has been mentioned before but I'm going to bring it up again in case it hasn't. Maybe someone can convince me that I'm wrong here.
Satellites come and satellites go. Since I got into C band in 1988 I've lost count of the different names that have been used for each new bird that was launched. Having said that I often wonder why people always use the name of the satellite instead of it's location in the arc? It just doesn't make sense to me to have to remember new names for satellites when they are constantly changing but the LOCATION usually stays the same?? When I setup my FTA systems I started out my channel lists by naming each satellite with it's position first, ie, 91_C_Galaxy17 or 91_K_Galaxy17. That way I don't necessarily have to keep track of names and I've got my satellite list in numerical order, which is where they are in the Clark Belt. The way stuff is usually posted now I have to go to my setup sheet and look for the satellite name to associate with a position in order to go there? It just doesn't make sense to do it this way??:confused: Or is it that I'm just old and suffer from "CRS"!;)
My opinion is this: It is easier in the psychology of the human brain to associate a name with something rather numbers.
Lets say you have 3 friends. 1st friend, Paul, lives at 91W Main Street, the second, James, at 99W Main Street, and the 3rd, Scott at 105W Main Street.
How often do you say hey lets go to 91W's house to hang out, you don't you say Paul's house. Now say Paul moves far far away. A new guy moves into the house at 91W Main Street, his name is Frank. You become good friends with Frank. Guess what, when you go there you refer to it as Frank's house, even though Paul is the one that built the house originally. Also, you still in going to see Frank don't say 91W
Just my opinion on the way the mind works.
I've been into satellite since 1982 and I always went by the name. In fact, when someone mentions for example that a channel is ITC at 87 I must always log onto Lyngsat to see that they are referring to SES2.
no matter what there are 4 types of folks out there when it comes to this
-folks who refer to them by name
-folks who refer to them by slot
-folks who refer to them by both
-folks who complain because someone else isn't doing it the same way they are ;)
I prefer orbital locations. They never change, and that is what I/my motor look for when moving or aiming the dish. It's simpler, easier and more accurate to locate.
I've used both but I'm real bad with some sat names
I called Horizon 2 (which was at 74) SBS6 for a long time
My Coolsat still has G10 as the sat at 123W ;)
If you and I were to meet and you told me your name and your phone number, two hours later I'd remember you phone number but not your name? But that's just me. ;-)
Not saying that either way is right or wrong mind you. I was just curious as to how others see this and it looks like most that have posted view it the same way I do.
LMAO - but I think you're dead on. I prefer the location rather than name as the original poster says. Location don't change - names do. Just my 2c.
when you hit the "sat" button on the remote, some receivers will bring up both name and location in the list automatically, so no renaming would be nessessary....however, some receivers will only bring up the name, which i guess is what you are referring to....never understood why that was....to me it seems logical to list them both....
the same is also true about the channel bar
When I was using the (analog) Toshiba to move the dish, it was SAT button then the last 2 digits of the location. SAT-7-2 (72W) or SAT-3-9 (139W) Never mind what the display said for satellite. FWIW:
AMAZ 26115T12
AMC110330
AMC27937T11
AMC38737.5NSS10
AMC410140.5NSS806
AMC57943I-11
AMC67245I-14
AMC713750I-1R
AMC813953I-707
AMC98355
AMC1013555.5I-805
AMC1113158I-16
AMC1510558I-9
AMC168561AMAZONAS 2
AMC1810561.5
12561.5
ANKF1107.362
ANKF2111.163T14R
ANKF3118.765StarOne C1
12172AMC6
61.574
61.578Simon Bolivar
G39579AMC5
G49983AMC9
G512587
G1012387SES2
G115589G28
G1213391G17
G1312793G25
G1412595G3
G1513397G19
G169999G16 G4
G1791110
G18123101SES1
G1997103AMC1
G23121105
G2593105AMC18
G2693107.3ANKF1
G2889111.1ANKF2
H1127113SATMEX6
H274116.8SATMEX5
Hispasat30118.7ANKF3
IA597121
IA693121G23
IA889123G18
IA13121125
IS1R50125G14
IS958127G13
IS1143127H1
IS1445133G12
IS1658133AMC11
IS70753135G15
IS80555.5137AMC10
NSS1037.5139AMC7
NSS80640.5139AMC8
SATMEX5116.8
SATMEX6113
SBS674
SES1101
SES287
T597
T693
T1137
T1215
T14R15
[TD="colspan: 4"] NAME TO LOCATION [/TD]
[TD="colspan: 2"] LOCATION TO NAME [/TD]
[TD="bgcolor: #E1E1E1, colspan: 6"] March 2012 [/TD]
[TD="bgcolor: #00FFFF"] Ku Only [/TD]
[TD="bgcolor: #FFFFFF, colspan: 3"]
[/TD]
[TD="bgcolor: #FFFFFF"]
[/TD]
[TD="bgcolor: #FFFF99"] Circular DSS [/TD]
[TD="bgcolor: #00FFFF"]Hispasat[/TD]
[TD="bgcolor: #00FFFF"]G11[/TD]
[TD="bgcolor: #FFFF99"]ECHO12[/TD]
[TD="bgcolor: #00FFFF"]AMC21[/TD]
[TD="bgcolor: #FFFF99"]ECHO15[/TD]
[TD="bgcolor: #FFFF66"]ECHO9[/TD]
[TD="bgcolor: #FFFF66"]ECHO12[/TD]
[TD="bgcolor: #00FFFF"]H2 SBS6[/TD]
[TD="bgcolor: #FFFF66"]ECHO15[/TD]
[TD="bgcolor: #00FFFF"]AMC16[/TD]
[TD="bgcolor: #FFFF99"]ECHO 10-11[/TD]
[TD="bgcolor: #00FFFF"]AMC15[/TD]
[TD="bgcolor: #FFFF99"]ECHO9[/TD]
Kept as an OpenOffice spreadsheat so it can be changed as needed.
I remember it both ways most of the time. I do hate when people post a Sat with a name that I don't use as much so I have to go look it up to see what slot it's in. That's why when I post one I try to just do both. I keep a chart I made up, handy though so it don't take to long to find it.
I want your used spun aluminum dish
Need remote for Toshiba TRX-1520
