satellite positions locking in on 119 nothings else so far | SatelliteGuys.US
DishInstallAdam
SatelliteGuys Guru
125
Iowa
first of all, zip code 52144, 211K with 1000.2. I have marked where I get a good signal on 119, but can't get 110, & 129 to lock in to there respective satellites. I currently have 209, 35 elevation 112 skew. how much do I move the dish to acquire all 3.
per dishpointer I get
33 elevation
217 azimuth
116 skew
so you might be getting the 119 sat on the 129 LNB so move a smidge west and down
Cover the outside 2 lnb's with aluminum foil to make sure you are receiveing 119 with the center lnb.
After that you should be able to hone in on the outer two satellites.
logitech revue and $4 monthly integration fee
New Dish Network HDDVR'S??
