Nothing unless you have some way to clean off the dish.After power outage, stuck on acquiring signal
What can be done till snow and ice melts?
That is what I thought. Can't reach the dish, on the roof. Will have to wait for it to thawNothing unless you have some way to clean off the dish.
Another POSSIBLE cause is if you have any barrels outdoors or a cut/slice in the cable that could allow water to get in, that could have corroded the connector.
Odds are it is snow/ice build up on the Dish/LNB.
If the dish is clear, go to diagnostics screen (Home 3 times) #3, set Tuner to if it shows 0 and back an the way out. It should start to acquire signalAfter power outage, stuck on acquiring signal
No.Did I imagine my H3 switching to a streaming channel of the satellite channel I was watching on Dish when weather knocked out the satellite feed?
This is what I am trying to get it to do, but it won't go past acquiring signal. Shows that on all 3 tuners of my hws.No.
This is called Signal Protector. If you are internet connected and have this feature enabled, you will be automatically switched to the IP feed (if available) when signal loss occurs.
Learn How DISH Satellite TV Provides a Reliable Signal 24/7
Experience strong signal coverage, no sudden outages, reliable service with DISH. Learn more about how DISH is a better option than cable TV companies.www.dish.com
Menu > Internet > AdvancedHow do you activate or check for signal protector? I have a H3.
Diagnostics-network-internet settings-Advanced[at top] is the exact way for a H3. Mine was turned off but Thank You for the right direction. Correction--We where both right. My BadMenu > Internet > Advanced
The power outage stopped Signal Protector from kicking back in, currently it lasts until a reboot of the Hopper, we are working to improve that in the next release.This is what I am trying to get it to do, but it won't go past acquiring signal. Shows that on all 3 tuners of my hws.
Is there a way to force it to use the internet?
Oh are you one of the developers? Please find my list of bugs from recent releases and fix those tooThe power outage stopped Signal Protector from kicking back in, currently it lasts until a reboot of the Hopper, we are working to improve that in the next release.
Please also find my list of bugs in recent releases and fix those as well.The power outage stopped Signal Protector from kicking back in, currently it lasts until a reboot of the Hopper, we are working to improve that in the next release.
Limited time offer
