Satellite Signal Question | SatelliteGuys.US
BigApe
6
Little Rock, Arkansas
I have had some digital glitches lately. Upon checking my signal strength I found all satellites and transponders at 90+ except the following…
Satellite 119 (B)
Transponder 20 – less than 20
Transponder 29 – at 0(zero)
Satellite 101 (A)
Transponder 12 – at 0(zero)
Transponder 18 – at 0(zero)
Transponder 20 – less than 40
Transponder 26 – at 0(zero)
Transponder 28 – at 0(zero)
Are these reading normal or is it time to realign the dish? :confused:
Thanks,
Joe
Satellite 119 (B)
Satellite 101 (A)
Thanks,
Joe
They are either not used, or used for locals, that are not in your area. You can see what is on the different transponders by going to this site:
http://www.widemovies.com/dtvtransponders.html
Dish adding 4 national hd channels
Dumb Question re HD Locals
