SatelliteGuys.US Bell ExpressVU Uplink Activity Report - Week Ending 09/01/2007 | SatelliteGuys.US
digiblur
14,190
4
Louisiana
SatelliteGuys.US Bell ExpressVU Uplink Activity Report - Week Ending 09/01/2007 - 54 changes
Uplink Comparison Range: 08/21/2007 01:00P - 08/27/2007 10:44P -
71 - LONDV [(0X89)] added to Nimiq1/4 91W TP 01 Canada/US beam (Available)
196 - NEWS1 moved from Nimiq1/4 91W TP 01 Canada/US beam to Nimiq1/4 91W TP 30 Canada/US beam (A)
230 - SWARE2 [MPEG2 SD] - Nimiq1/4 91W TP 06 Canada/US beam changed to Available
299 - MOVIE (A) removed from Nimiq1/4 91W TP 15 Canada/US beam
388 - GOLSP moved from Nimiq2/3 82W TP 05 Canada/Non SE US beam to Nimiq1/4 91W TP 17 Canada/US beam (A)
389 - WLDTV moved from Nimiq2/3 82W TP 04 Canada/US beam to Nimiq1/4 91W TP 15 Canada/US beam (A)
390 - FIGHT moved from Nimiq2/3 82W TP 05 Canada/Non SE US beam to Nimiq1/4 91W TP 13 Canada/US beam (A)
392 - NCAA2 Nimiq1/4 91W TP 29 Canada/US beam changed from (0X89) to MPEG2 SD (A)
393 - NCAA3 Nimiq1/4 91W TP 30 Canada/US beam changed from (0X89) to MPEG2 SD (A)
394 - NCAA4 Nimiq1/4 91W TP 13 Canada/US beam changed from (0X89) to MPEG2 SD (A)
395 - NCAA5 Nimiq1/4 91W TP 04 Canada/US beam changed from (0X89) to MPEG2 SD (A)
396 - NCAA6 Nimiq1/4 91W TP 04 Canada/US beam changed from (0X89) to MPEG2 SD (A)
397 - NCAA7 Nimiq2/3 82W TP 30 Canada/US beam changed from (0X89) to MPEG2 HD (A)
398 - NCAA8 Nimiq2/3 82W TP 30 Canada/US beam changed from (0X89) to MPEG2 HD (A)
404 - GOLTV moved from Nimiq2/3 82W TP 05 Canada/Non SE US beam to Nimiq1/4 91W TP 17 Canada/US beam (A)
418 - MLBEI renamed to NFLST (A)
419 - WFN moved from Nimiq2/3 82W TP 05 Canada/Non SE US beam to Nimiq1/4 91W TP 21 Canada/US beam (A)
451 - NFL1 [MPEG2 SD] - Nimiq1/4 91W TP 25 Canada/US beam changed to Not Available
452 - NFL2 [(0X89)] - Nimiq1/4 91W TP 15 Canada/US beam changed to Not Available
453 - NFL3 [(0X89)] - Nimiq1/4 91W TP 08 Canada/US beam changed to Not Available
454 - NFL4 [(0X89)] - Nimiq1/4 91W TP 06 Canada/US beam changed to Not Available
455 - NFL5 [(0X89)] - Nimiq1/4 91W TP 21 Canada/US beam changed to Not Available
456 - NFL6 [(0X89)] - Nimiq1/4 91W TP 10 Canada/US beam changed to Not Available
457 - NFL7 [(0X89)] - Nimiq1/4 91W TP 29 Canada/US beam changed to Not Available
458 - NFL8 [(0X89)] - Nimiq1/4 91W TP 30 Canada/US beam changed to Not Available
459 - NFL9 [(0X89)] - Nimiq1/4 91W TP 13 Canada/US beam changed to Not Available
460 - NFL10 [(0X89)] - Nimiq1/4 91W TP 04 Canada/US beam changed to Not Available
465 - NFLH1 [(0X89)] - Nimiq2/3 82W TP 18 Canada/US beam changed to Not Available
466 - NFLH2 [(0X89)] - Nimiq2/3 82W TP 18 Canada/US beam changed to Not Available
467 - NFLH3 [(0X89)] - Nimiq2/3 82W TP 12 Canada/Non SE US beam changed to Not Available
468 - NFLH4 [(0X89)] - Nimiq2/3 82W TP 12 Canada/Non SE US beam changed to Not Available
860 - SRCHE moved from Nimiq2/3 82W TP 09 Canada/Non SE US beam to Nimiq2/3 82W TP 23 Canada/US beam (A)
870 - NFLH1* [(0X89)] - Nimiq2/3 82W TP 18 Canada/US beam changed to Not Available
871 - NFLH2* [(0X89)] - Nimiq2/3 82W TP 18 Canada/US beam changed to Not Available
872 - NFLH3* [(0X89)] - Nimiq2/3 82W TP 12 Canada/Non SE US beam changed to Not Available
873 - NFLH4* [(0X89)] - Nimiq2/3 82W TP 12 Canada/Non SE US beam changed to Not Available
885 - FTA-1 renamed to MPHD1 (NA)
886 - FTA-2 renamed to MPHD2 (NA)
887 - 206-3 renamed to MPHD3 (NA)
888 - 206-4 renamed to MPHD4 (NA)
8451 - NFL1H [(0X89)] - Nimiq1/4 91W TP 25 Canada/US beam changed to Not Available
8452 - NFL2H [(0X89)] - Nimiq1/4 91W TP 15 Canada/US beam changed to Not Available
8453 - NFL3H [(0X89)] - Nimiq1/4 91W TP 08 Canada/US beam changed to Not Available
8454 - NFL4H [(0X89)] - Nimiq1/4 91W TP 06 Canada/US beam changed to Not Available
8455 - NFL5H [(0X89)] - Nimiq1/4 91W TP 21 Canada/US beam changed to Not Available
8456 - NFL6H [(0X89)] - Nimiq1/4 91W TP 10 Canada/US beam changed to Not Available
8457 - NFL7H [(0X89)] - Nimiq1/4 91W TP 29 Canada/US beam changed to Not Available
8458 - NFL8H [(0X89)] - Nimiq1/4 91W TP 30 Canada/US beam changed to Not Available
8459 - NFL9H [(0X89)] - Nimiq1/4 91W TP 13 Canada/US beam changed to Not Available
8460 - NF10H [(0X89)] - Nimiq1/4 91W TP 04 Canada/US beam changed to Not Available
9888 - NSTI moved from Nimiq1/4 91W TP 08 Canada/US beam to Nimiq1/4 91W TP 25 Canada/US beam (A)
9888 - NSTI [(0X89)] added to Nimiq1/4 91W TP 08 Canada/US beam (Available)
36862 - EPG2 moved from Nimiq2/3 82W TP 03 Canada/US beam to Nimiq1/4 91W TP 01 Canada/US beam and changed to EPG (A)
Transponder Changes:
Nimiq2/3 82W TP 09 Canada/Non SE US beam QPSK removed from tables
Channels in the system: 812
(A) = Available to subscribers
(NA) = Not Available
SatelliteGuys.US Bell ExpressVU Uplink Activity Report - Week Ending 09/01/2007 - 2 changes
Uplink Comparison Range: 08/27/2007 10:44P - 08/28/2007 10:56P -
860 - SRCHE moved from Nimiq2/3 82W TP 23 Canada/US beam to Nimiq2/3 82W TP 09 Canada/Non SE US beam (A)
Nimiq2/3 82W TP 09 Canada/Non SE US beam QPSK added to tables
Looks like they moved Fight TV then from 82 West to 91 West
Together with WildTV and GolSP as well.....
Also .. it looks like Bev finally added 9 day Extended EPG guide on Aug. 27th, 2007 ..
According to that forum's announcement anyhow:
"9 Day EPG was turned on this morning. This new feature is available on PVR set-top boxes."
Yup.. It's official:
"Dear Affiliates,
Please be advised that due to technical issues the following services have be moved from 82 degrees to 91 degrees effective immediately:
Wild TV - Ch. 389 Transponder 15
GoL TV - Ch. 404 Transponder 17
GoL SP - Ch. 388 Transponder 17
FIGHT - Ch. 390 Transponder 13
WFN - Ch. 419 Transponder 21"
OK.. - i wasn't following it that closely i guess..
Just noticed their announcement another day..
P.S. I thought i DID see EEPG mention however.. (just didn't think much of it, for some reason, i guess) :)
Maybe they make room for new HD channels.
Don't forget Bell has already promised 4 HD channels...TVA HD, TQS HD, RDS HD and CBC HD West
moving 2 SD channels to 91 ain't gonna make the room for 2 HD channels
in MPEG2 its 2 HD channels per TP...MPEG4 is 4 per TP
MPEG2 SD is 12 per Tp :)
no but droping Much Loud and a few more will. If I recall I think they either dropped or moved at ;east 6 or 7 channels from 82, and the ones the recently added I think are on 91.
I think this is due the Super Channel HD coming a few more HD channels.
...I think this is due the Super Channel HD coming...
There are two of them at the moment in testing phase running the same mixture of other BEV HD channels at around 10Mbps, 720/60p:
SCHD1: TP 12559 sharing with Discovery HD and NBC HD East
SCHD2: TP 12355 sharing with nonactive SNHD2 and ABC HD West
Diogen.
actually .. in the first post of this thread.. i think it says EPG2 .. changed to EPG...
What a heck? :)
So where is EEPG then... :rolleyes:
Or is that it? :)
Expressvu Price increase
9-day Guide on BEV PVR's
