SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 01/12/2008 | SatelliteGuys.US
  • Thread starter Thread starter digiblur
  • Start date Start date
  • Replies Replies 0
  • Views Views 3K
digiblur
14,190
4
Louisiana
CLICK HERE for the Uplink Discussion Thread
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 01/12/2008 - 44 changes
Uplink Comparison Range: 01/08/2008 04:01P - 01/09/2008 11:55A -
157 - IMF renamed to OVATN (A)
654 - JSTV (A) removed from EchoStar1 148W TP 25 ConUS beam
654 - JSTV (A) removed from EchoStar3 61.5W TP 12 ConUS beam
655 - WOWTV moved from EchoStar1 148W TP 03 ConUS beam to EchoStar1 148W TP 07 ConUS beam (A)
655 - WOWTV moved from EchoStar3 61.5W TP 10 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A)
705 - ARANG (A) removed from EchoStar9 121W TP 05 ConUS beam
716 - VIDIT moved from EchoStar1 148W TP 01 ConUS beam to EchoStar1 148W TP 07 ConUS beam (A)
716 - VIDIT moved from EchoStar3 61.5W TP 27 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A)
727 - VIDIT (A) removed from EchoStar9 121W TP 13 ConUS beam
739 - RTVI+ (A) removed from EchoStar9 121W TP 13 ConUS beam
747 - ARYOW (A) removed from EchoStar9 121W TP 13 ConUS beam
795 - SUNTV (A) removed from EchoStar9 121W TP 13 ConUS beam
815 - RCORD moved from EchoStar9 121W TP 15 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
817 - SPT moved from EchoStar9 121W TP 18 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
908 - RAD60 (A) removed from EchoStar1 148W TP 09 ConUS beam
908 - RAD60 (A) removed from EchoStar3 61.5W TP 08 ConUS beam
909 - RADIT (A) removed from EchoStar1 148W TP 01 ConUS beam
909 - RADIT (A) removed from EchoStar3 61.5W TP 27 ConUS beam
910 - RAIRD (A) removed from EchoStar2 148W TP 24 ConUS beam
910 - RAIRD (A) removed from Echostar12 61.5W TP 15 ConUS beam
5708 - RCORD [MPEG2 SD] added to EchoStar9 121W TP 15 ConUS beam (Available)
5709 - SPT [MPEG2 SD] added to EchoStar9 121W TP 18 ConUS beam (Available)
5722 - VIDIT [MPEG2 SD] added to EchoStar1 148W TP 01 ConUS beam (Available)
5722 - VIDIT [MPEG2 SD] added to EchoStar3 61.5W TP 27 ConUS beam (Available)
5724 - WOWTV [MPEG2 SD] added to EchoStar1 148W TP 03 ConUS beam (Available)
5724 - WOWTV [MPEG2 SD] added to EchoStar3 61.5W TP 10 ConUS beam (Available)
5956 - MP241 EchoStar2 148W TP 10 ConUS beam changed from MPEG2 SD to MPEG4 SD (NA)
5957 - MP242 EchoStar2 148W TP 10 ConUS beam changed from MPEG2 SD to MPEG4 SD (NA)
5958 - MP243 EchoStar2 148W TP 10 ConUS beam changed from MPEG2 SD to MPEG4 SD (NA)
5992 - MPT02 (NA) removed from EchoStar1 148W TP 15 ConUS beam
7199(7) - INFO [MPEG2 SD] added to AMC-15 105W TP 02 ConUS beam (Available)
7208(26) - INFO [MPEG2 SD] added to AMC-15 105W TP 02 ConUS beam (Available)
7314(9) - INFO [MPEG2 SD] added to AMC-15 105W TP 02 ConUS beam (Available)
7326(31) - INFO [MPEG2 SD] added to AMC-15 105W TP 02 ConUS beam (Available)
7424(4) - INFO [MPEG2 SD] added to AMC-15 105W TP 02 ConUS beam (Available)
7432(44) - INFO [MPEG2 SD] added to AMC-15 105W TP 02 ConUS beam (Available)
7472 - WKBS moved from EchoStar10 110W TP 29 Spotbeam 09 to EchoStar7 119W TP 01 Northeast beam (A)
7928(17) - INFO [MPEG2 SD] added to AMC-15 105W TP 02 ConUS beam (Available)
7934(28) - INFO [MPEG2 SD] added to AMC-15 105W TP 02 ConUS beam (Available)
9219(46) - WTVK renamed to WXCW (A)
9544 - NHLHD moved from EchoStar5 129W TP 08 ConUS beam to EchoStar5 129W TP 27 ConUS beam (A)
Transponder Changes:
EchoStar2 148W TP 10 ConUS beam changed modulation scheme from QPSK to 8PSK
EchoStar2 148W TP 10 ConUS beam changed symbol rate from 20000 MSPS to 21500 MSPS
EchoStar2 148W TP 10 ConUS beam changed FEC from 5/6 to 2/3
Channels in the system: 4554
(A) = Available to subscribers
(NA) = Not Available
What is DishinItUp?
Some 722 upgrade questions
