You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
- Status
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 06/09/2007 - 1 change
Uplink Comparison Range: 06/04/2007 09:57A - 06/04/2007 01:19P -
117 - TVGC renamed to TVGN (A)
Channels in the system: 3799
(A) = Available to subscribers
(NA) = Not Available
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 06/09/2007 - 13 changes
Uplink Comparison Range: 06/06/2007 08:14A - 06/06/2007 11:45A -
281 - SOAP EchoStar8 110W TP 11 ConUS beam changed to SPEED - EchoStar7 119W TP 17 ConUS beam (A)
282 - WE EchoStar7 119W TP 12 ConUS beam changed to SLTH - EchoStar8 110W TP 19 ConUS beam (A)
283 - OXYGN EchoStar7 119W TP 17 ConUS beam changed to MLTRY - EchoStar8 110W TP 21 ConUS beam (A)
284 - PELIC EchoStar8 110W TP 01 ConUS beam changed to ESPCL - EchoStar7 119W TP 04 ConUS beam (A)
285 - MUN2 EchoStar8 110W TP 09 ConUS beam changed to ESPND - EchoStar8 110W TP 05 ConUS beam (A)
473 - OPEN1 EchoStar7 119W TP 18 ConUS beam moved to EchoStar8 110W TP 16 ConUS beam
474 - OPEN2 EchoStar7 119W TP 10 ConUS beam moved to EchoStar7 119W TP 18 ConUS beam
475 - OPEN3 EchoStar8 110W TP 16 ConUS beam moved to EchoStar7 119W TP 12 ConUS beam
476 - OPEN4 EchoStar7 119W TP 18 ConUS beam moved to EchoStar8 110W TP 16 ConUS beam
477 - OPEN5 EchoStar7 119W TP 12 ConUS beam moved to EchoStar7 119W TP 18 ConUS beam
5828 - SOON3 [VOD] added to EchoStar8 110W TP 14 ConUS beam (Not Available)
5829 - SOON4 [VOD] added to EchoStar7 119W TP 16 ConUS beam (Not Available)
19068 - TCHEF [(0X89)] added to EchoStar7 119W TP 02 ConUS beam (Not Available)
Channels in the system: 3802
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 06/09/2007 - 31 changes
Uplink Comparison Range: 06/08/2007 08:18A - 06/08/2007 04:04P -
141 - ESPNA [MPEG2 SD] added to EchoStar8 110W TP 24 ConUS beam (Available)
147 - ESPNA [MPEG2 SD] added to EchoStar8 110W TP 16 ConUS beam (Available)
5601 - KIMO1 [MPEG4 SD] - EchoStar10 110W TP 31 Spotbeam 47(HI) changed to Available
5602 - KIMO2 [MPEG4 SD] - EchoStar10 110W TP 04 Spotbeam 46(AK) changed to Available
5604 - KTVA [MPEG4 HD] - EchoStar10 110W TP 04 Spotbeam 46(AK) changed to Available
5621 - KAKM [MPEG4 HD] - EchoStar10 110W TP 04 Spotbeam 46(AK) changed to Available
5622 - KAKM2 [MPEG4 SD] - EchoStar10 110W TP 31 Spotbeam 47(HI) changed to Available
5626 - KDMD1 [MPEG4 SD] - EchoStar10 110W TP 31 Spotbeam 47(HI) changed to Available
5627 - KDMD2 [MPEG4 SD] - EchoStar10 110W TP 04 Spotbeam 46(AK) changed to Available
5631 - KATN1 [MPEG4 SD] - EchoStar2 148W TP 14 ConUS beam changed to Available
5643 - KFXF1 [MPEG4 SD] - EchoStar2 148W TP 14 ConUS beam changed to Available
5647 - KUAC2 [MPEG4 SD] - EchoStar2 148W TP 14 ConUS beam changed to Available
5651 - KJNP1 [MPEG4 SD] - EchoStar2 148W TP 14 ConUS beam changed to Available
5655 - KITV [MPEG4 HD] - EchoStar10 110W TP 23 Spotbeam 47 changed to Available
5656 - KITV renamed to KITV3 (NA)
5657 - KITV2 [MPEG4 SD] - EchoStar10 110W TP 31 Spotbeam 47(HI) changed to Available
5659 - KGMB [MPEG4 HD] - EchoStar10 110W TP 23 Spotbeam 47 changed to Available
5663 - KHNL [MPEG4 HD] - EchoStar10 110W TP 23 Spotbeam 47 changed to Available
5665 - KHNL2 [MPEG4 SD] - EchoStar10 110W TP 31 Spotbeam 47(HI) changed to Available
5667 - KHON [MPEG4 HD] - EchoStar10 110W TP 23 Spotbeam 47 changed to Available
5669 - KHON2 [MPEG4 SD] - EchoStar10 110W TP 31 Spotbeam 47(HI) changed to Available
5671 - KFVE [MPEG4 HD] - EchoStar10 110W TP 23 Spotbeam 47 changed to Available
5674 - KHET [MPEG4 HD] - EchoStar10 110W TP 23 Spotbeam 47 changed to Available
5675 - KHET2 [MPEG4 SD] - EchoStar10 110W TP 31 Spotbeam 47(HI) changed to Available
5679 - KWHE1 [MPEG4 SD] - EchoStar10 110W TP 31 Spotbeam 47(HI) changed to Available
5682 - KIKU1 [MPEG4 SD] - EchoStar10 110W TP 31 Spotbeam 47(HI) changed to Available
5688 - KJUD1 [MPEG4 SD] - EchoStar2 148W TP 14 ConUS beam changed to Available
5689 - KJUD2 [MPEG4 SD] - EchoStar2 148W TP 14 ConUS beam changed to Available
5703 - KTOO [MPEG4 HD] - EchoStar2 148W TP 22 ConUS beam changed to Available
5704 - KTOO1 [MPEG4 SD] - EchoStar2 148W TP 14 ConUS beam changed to Available
5705 - KTOO3 [MPEG4 SD] - EchoStar2 148W TP 14 ConUS beam changed to Available
Channels in the system: 3804
- Status
