SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 09/29/2007 | SatelliteGuys.US
digiblur
14,190
4
Louisiana
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 09/29/2007 - 51 changes
Uplink Comparison Range: 09/24/2007 08:40A - 09/26/2007 12:41P -
104 - SRI [MPEG2 SD] - EchoStar7 119W TP 11 ConUS beam changed to Available
284 - SETA (NA) removed from EchoStar8 110W TP 06 ConUS beam
285 - ESPND (NA) removed from EchoStar8 110W TP 05 ConUS beam
286 - REAL (NA) removed from EchoStar8 110W TP 05 ConUS beam
288 - SHO-E [MPEG2 SD] added to EchoStar7 119W TP 06 ConUS beam (Available)
289 - SHO-W [MPEG2 SD] added to EchoStar7 119W TP 08 ConUS beam (Available)
290 - SHOTO [MPEG2 SD] added to EchoStar7 119W TP 19 ConUS beam (Available)
291 - SHOCS [MPEG2 SD] added to EchoStar8 110W TP 21 ConUS beam (Available)
292 - SHOEX [MPEG2 SD] added to EchoStar7 119W TP 16 ConUS beam (Available)
293 - SBYND [MPEG2 SD] added to EchoStar8 110W TP 11 ConUS beam (Available)
294 - TMC-E [MPEG2 SD] added to EchoStar7 119W TP 10 ConUS beam (Available)
295 - TMCXE [MPEG2 SD] added to EchoStar7 119W TP 10 ConUS beam (Available)
296 - SUND [MPEG2 SD] added to EchoStar7 119W TP 12 ConUS beam (Available)
297 - FLIX [MPEG2 SD] added to EchoStar7 119W TP 17 ConUS beam (Available)
359 - CSNWS [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
360 - ALTUD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
374 - CSNMA [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
374 - CSNMA [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
375 - FOXOH [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
386 - FOXN moved from EchoStar5 129W TP 08 ConUS beam to EchoStar5 129W TP 27 ConUS beam (A)
544 - NHL [MPEG2 SD] - EchoStar7 119W TP 13 ConUS beam changed to Available
545 - NHL [MPEG2 SD] - EchoStar7 119W TP 10 ConUS beam changed to Available
546 - NHL [MPEG2 SD] - EchoStar7 119W TP 12 ConUS beam changed to Available
547 - NHL [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Available
548 - NHL [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Available
549 - NHL [MPEG2 SD] - EchoStar7 119W TP 21 ConUS beam changed to Available
550 - NHL [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Available
551 - NHL [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Available
552 - NHL [MPEG2 SD] - EchoStar7 119W TP 21 ConUS beam changed to Available
553 - NHL [MPEG2 SD] - EchoStar8 110W TP 24 ConUS beam changed to Available
554 - NHL [MPEG2 SD] - EchoStar7 119W TP 10 ConUS beam changed to Available
555 - NHL [MPEG2 SD] - EchoStar7 119W TP 12 ConUS beam changed to Available
556 - NHL [MPEG2 SD] - EchoStar7 119W TP 13 ConUS beam changed to Available
557 - NHL [MPEG2 SD] - EchoStar7 119W TP 21 ConUS beam changed to Available
558 - NHL [MPEG2 SD] - EchoStar7 119W TP 10 ConUS beam changed to Available
576 - ZEESA [MPEG2 SD] - EchoStar7 119W TP 21 ConUS beam changed to Available
576 - ZEESA [MPEG2 SD] - EchoStar3 61.5W TP 12 ConUS beam changed to Available
5992 - XKNXV [MPEG2 SD] added to EchoStar7 119W TP 05 Arizona beam (Not Available)
5993 - XKPHO [MPEG2 SD] added to EchoStar7 119W TP 05 Arizona beam (Not Available)
5994 - XKPNX [MPEG2 SD] added to EchoStar7 119W TP 05 Arizona beam (Not Available)
5995 - XKSAZ [MPEG2 SD] added to EchoStar7 119W TP 05 Arizona beam (Not Available)
5996 - XKTVK [MPEG2 SD] added to EchoStar7 119W TP 05 Arizona beam (Not Available)
5997 - XKTVW [MPEG2 SD] added to EchoStar7 119W TP 05 Arizona beam (Not Available)
5998 - XKTAZ [MPEG2 SD] added to EchoStar7 119W TP 05 Arizona beam (Not Available)
5999 - XKFPH [MPEG2 SD] added to EchoStar7 119W TP 05 Arizona beam (Not Available)
7648 - KFBI [MPEG2 SD] added to EchoStar2 148W TP 18 ConUS beam (Not Available)
9421 - DSCHD renamed to HDTHR (A)
9443 - HDTV3 (A) removed from EchoStar3 61.5W TP 20 ConUS beam
9510 - VERIA (NA) removed from EchoStar8 110W TP 03 ConUS beam
9575 - VERIA [MPEG2 SD] added to EchoStar8 110W TP 03 ConUS beam (Not Available)
Transponder Changes:
EchoStar3 61.5W TP 20 ConUS beam 8PSK removed from tables
Channels in the system: 4460
(A) = Available to subscribers
(NA) = Not Available
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 09/29/2007 - 1 change
Uplink Comparison Range: 09/26/2007 03:58P - 09/26/2007 08:43P -
5500 - DSCHD renamed to HDTHR (A)
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 09/29/2007 - 22 changes
Uplink Comparison Range: 09/26/2007 08:43P - 09/27/2007 06:36A -
285 - SHO-E [MPEG2 HD] added to EchoStar8 110W TP 13 ConUS beam (Not Available)
5708 - RTST1 [MPEG4 HD] added to EchoStar5 129W TP 02 ConUS beam (Not Available)
5709 - RTST2 [MPEG4 HD] added to EchoStar5 129W TP 02 ConUS beam (Not Available)
5860 - RSSM moved from EchoStar2 148W TP 02 ConUS beam to EchoStar1 148W TP 27 ConUS beam (NA)
6210 - KNXV [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 35(AZ) (Not Available)
6211 - KPHO [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 35(AZ) (Not Available)
6212 - KPNX [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 35(AZ) (Not Available)
6213 - KSAZ [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 35(AZ) (Not Available)
6214 - KASW [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 35(AZ) (Not Available)
6215 - KUTP [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 35(AZ) (Not Available)
6216 - KAET [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 35(AZ) (Not Available)
6217 - KTVK [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 35(AZ) (Not Available)
6218 - KTVW [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 35(AZ) (Not Available)
6219 - KTAZ [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 35(AZ) (Not Available)
6220 - KFPH [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 35(AZ) (Not Available)
6221 - KAZT [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 35(AZ) (Not Available)
6222 - KMOH [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 35(AZ) (Not Available)
6450 - KTVK moved from EchoStar10 110W TP 20 Spotbeam 35(AZ) to EchoStar10 110W TP 18 Spotbeam 35 (A)
8338 - KMOH moved from EchoStar7 119W TP 07 Arizona beam to EchoStar7 119W TP 05 Arizona beam (A)
EchoStar10 110W TP 20 Spotbeam 35(AZ) changed modulation scheme from 8PSK to QPSK
EchoStar10 110W TP 20 Spotbeam 35(AZ) changed symbol rate from 21500 MSPS to 20000 MSPS
EchoStar10 110W TP 18 Spotbeam 35 changed FEC from 2/3 to 5/6
Channels in the system: 4476
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 09/29/2007 - 11 changes
Uplink Comparison Range: 09/27/2007 06:36A - 09/27/2007 12:23P -
288 - SHO-E [MPEG2 SD] - EchoStar7 119W TP 06 ConUS beam changed to Not Available
289 - SHO-W [MPEG2 SD] - EchoStar7 119W TP 08 ConUS beam changed to Not Available
290 - SHOTO [MPEG2 SD] - EchoStar7 119W TP 19 ConUS beam changed to Not Available
291 - SHOCS [MPEG2 SD] - EchoStar8 110W TP 21 ConUS beam changed to Not Available
292 - SHOEX [MPEG2 SD] - EchoStar7 119W TP 16 ConUS beam changed to Not Available
293 - SBYND [MPEG2 SD] - EchoStar8 110W TP 11 ConUS beam changed to Not Available
294 - TMC-E [MPEG2 SD] - EchoStar7 119W TP 10 ConUS beam changed to Not Available
295 - TMCXE [MPEG2 SD] - EchoStar7 119W TP 10 ConUS beam changed to Not Available
296 - SUND [MPEG2 SD] - EchoStar7 119W TP 12 ConUS beam changed to Not Available
297 - FLIX [MPEG2 SD] - EchoStar7 119W TP 17 ConUS beam changed to Not Available
5862 - SPEC1 EchoStar1 148W TP 23 ConUS beam changed from TV to MPEG2 SD (NA)
Uplink Comparison Range: 09/27/2007 12:23P - 09/27/2007 11:06P -
285 - SHO-E [MPEG2 HD] - EchoStar8 110W TP 13 ConUS beam changed to Available
288 - SHO-E [MPEG2 SD] - EchoStar7 119W TP 06 ConUS beam changed to Available
289 - SHO-W [MPEG2 SD] - EchoStar7 119W TP 08 ConUS beam changed to Available
290 - SHOTO [MPEG2 SD] - EchoStar7 119W TP 19 ConUS beam changed to Available
291 - SHOCS [MPEG2 SD] - EchoStar8 110W TP 21 ConUS beam changed to Available
292 - SHOEX [MPEG2 SD] - EchoStar7 119W TP 16 ConUS beam changed to Available
293 - SBYND [MPEG2 SD] - EchoStar8 110W TP 11 ConUS beam changed to Available
294 - TMC-E [MPEG2 SD] - EchoStar7 119W TP 10 ConUS beam changed to Available
295 - TMCXE [MPEG2 SD] - EchoStar7 119W TP 10 ConUS beam changed to Available
296 - SUND [MPEG2 SD] - EchoStar7 119W TP 12 ConUS beam changed to Available
297 - FLIX [MPEG2 SD] - EchoStar7 119W TP 17 ConUS beam changed to Available
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 09/29/2007 - 2 changes
Uplink Comparison Range: 09/28/2007 12:12A - 09/28/2007 11:27A -
377 - FOXCN moved from EchoStar5 129W TP 08 ConUS beam to EchoStar5 129W TP 27 ConUS beam (A)
378 - FOXPT moved from EchoStar5 129W TP 08 ConUS beam to EchoStar5 129W TP 27 ConUS beam (A)
Upgrade Info Needed
Burning Programs to dvd question
