SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 11/03/2007 | SatelliteGuys.US
digiblur
14,190
4
Louisiana
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 11/03/2007 - 15 changes
Uplink Comparison Range: 10/29/2007 08:59A - 10/29/2007 12:54P -
285 - SHO-E [MPEG2 HD] - EchoStar8 110W TP 13 ConUS beam changed to Not Available
288 - SHO-E [MPEG2 SD] - EchoStar7 119W TP 06 ConUS beam changed to Not Available
289 - SHO-W [MPEG2 SD] - EchoStar7 119W TP 08 ConUS beam changed to Not Available
290 - SHOTO [MPEG2 SD] - EchoStar7 119W TP 19 ConUS beam changed to Not Available
291 - SHOCS [MPEG2 SD] - EchoStar8 110W TP 21 ConUS beam changed to Not Available
292 - SHOEX [MPEG2 SD] - EchoStar7 119W TP 16 ConUS beam changed to Not Available
293 - SBYND [MPEG2 SD] - EchoStar8 110W TP 11 ConUS beam changed to Not Available
294 - TMC-E [MPEG2 SD] - EchoStar7 119W TP 10 ConUS beam changed to Not Available
295 - TMCXE [MPEG2 SD] - EchoStar7 119W TP 10 ConUS beam changed to Not Available
296 - SUND [MPEG2 SD] - EchoStar7 119W TP 12 ConUS beam changed to Not Available
297 - FLIX [MPEG2 SD] - EchoStar7 119W TP 17 ConUS beam changed to Not Available
9508 - NBATV(402) [MPEG4 HD] - EchoStar5 129W TP 06 ConUS beam changed to Available
9508 - NBATV(402) [MPEG4 HD] - EchoStar3 61.5W TP 22 ConUS beam changed to Available
9509 - NBATV(560) [MPEG4 HD] - EchoStar5 129W TP 06 ConUS beam changed to Available
9509 - NBATV(560) [MPEG4 HD] - EchoStar3 61.5W TP 22 ConUS beam changed to Available
Channels in the system: 4466
(A) = Available to subscribers
(NA) = Not Available
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 11/03/2007 - 40 changes
Uplink Comparison Range: 10/31/2007 08:28A - 10/31/2007 12:16P -
216 - DISH renamed to C&T (A)
219 - DISH renamed to ALIVE (A)
221 - DISH renamed to LSHOP (A)
229 - DISH renamed to GEMS (A)
281 - VERIA EchoStar8 110W TP 03 ConUS beam changed to FUSE - EchoStar7 119W TP 02 ConUS beam (A)
282 - VS. EchoStar8 110W TP 01 ConUS beam MPEG2 SD changed to IMF - EchoStar8 110W TP 03 ConUS beam
283 - FSC EchoStar8 110W TP 11 ConUS beam MPEG2 SD changed to FX - EchoStar7 119W TP 12 ConUS beam
284 - GAC [MPEG2 SD] added to EchoStar8 110W TP 11 ConUS beam (Available)
542 - NHL [MPEG2 SD] added to EchoStar8 110W TP 24 ConUS beam (Available)
574 - FPCHN EchoStar1 148W TP 27 ConUS beam moved to EchoStar1 148W TP 07 ConUS beam
574 - FPCHN EchoStar3 61.5W TP 16 ConUS beam moved to EchoStar3 61.5W TP 14 ConUS beam
575 - FPCHN EchoStar1 148W TP 27 ConUS beam moved to EchoStar1 148W TP 11 ConUS beam
575 - FPCHN EchoStar3 61.5W TP 16 ConUS beam moved to EchoStar3 61.5W TP 18 ConUS beam
713 - VIVA (A) removed from EchoStar9 121W TP 13 ConUS beam
714 - NBN4 (A) removed from EchoStar9 121W TP 13 ConUS beam
715 - RPN9 (A) removed from EchoStar9 121W TP 13 ConUS beam
732 - RFI (A) removed from EchoStar9 121W TP 10 ConUS beam
735 - TRACE (A) removed from EchoStar9 121W TP 18 ConUS beam
751 - TELSD (A) removed from EchoStar9 121W TP 05 ConUS beam
800 - SURYA (A) removed from EchoStar9 121W TP 13 ConUS beam
801 - KAIRA (A) removed from EchoStar9 121W TP 06 ConUS beam
803 - UDAYA (A) removed from EchoStar9 121W TP 26 ConUS beam
905 - ARMTV (A) removed from EchoStar9 121W TP 05 ConUS beam
982 - HMUSC [RADIO] added to EchoStar7 119W TP 12 ConUS beam (Not Available)
5714 - CHNLI (A) removed from EchoStar9 121W TP 06 ConUS beam
5715 - GEMNI (A) removed from EchoStar9 121W TP 15 ConUS beam
5718 - GKINO (A) removed from EchoStar9 121W TP 22 ConUS beam
5719 - DWTV (A) removed from EchoStar9 121W TP 18 ConUS beam
5720 - PRSBN (A) removed from EchoStar9 121W TP 22 ConUS beam
5992 - XKNXV (A) removed from EchoStar7 119W TP 05 Arizona beam
5993 - XKPHO (A) removed from EchoStar7 119W TP 05 Arizona beam
5994 - XKPNX (A) removed from EchoStar7 119W TP 05 Arizona beam
5995 - XKSAZ (A) removed from EchoStar7 119W TP 05 Arizona beam
5996 - XKTVK (A) removed from EchoStar7 119W TP 05 Arizona beam
5997 - XKTVW (A) removed from EchoStar7 119W TP 05 Arizona beam
5998 - XKTAZ (A) removed from EchoStar7 119W TP 05 Arizona beam
5999 - XKFPH (A) removed from EchoStar7 119W TP 05 Arizona beam
8795 - PBS (A) removed from EchoStar7 119W TP 08 ConUS beam
9542 - NHLHD(542) [MPEG4 HD] added to EchoStar5 129W TP 08 ConUS beam (Available)
9542 - NHLHD(542) [MPEG4 HD] added to EchoStar3 61.5W TP 30 ConUS beam (Available)
Channels in the system: 4447
Dish DVR Vs. Cox DVR Vs. TiVo?
adding a 311 to existing setup
