i am looking for a great sat finder thanks.
I was looking at a GT Media V8 Finder, Is there something else that would consider better ?Do you mean you need a portable device you can plug in to the LNB and use to measure signal strength while you are adjusting the aim?
I have a GT Media V8 Finder, not the best in the world but it only cost about $50 if I remember correctly.
I use an Applied Instruments XR-3 with a VSAT-ACM plugin. Lots of bells and whistles for locating satellites. It'll even tell you what satellite you're looking at by name and position. Pricey instrument though.thanks zetamale i have all of that.but i still need one to set up and do some finding.i have a 10ft and a 90cm for fta,thanks i am retired and i am finding something extra to do.
Limited time offer
