Sathero Meter | SatelliteGuys.US
Sathero Meter
Stratton
12
Greensboro North Carolina
Does anyone happen to have any experience loading North American transponder lists onto a Sathero SH-100HD ? I have an excel file with the lists of TPs that I got from their website but I don't know how to load it onto the meter. The meter is pre-loaded with European TPs.
Been awhile since I have done it. But, do remember that Linux won't work to copy the file to the SH-100, had to use windows. Do a google search for that model and you should find the manual or at least better instructions on how to do it. I remember copying the file to the SH-100 and then hooking up the meter. It then loaded the list. Good luck finding the instructions. If I remember correctly, that is where I found out how to do it.
SAB Android I HD Satellite Receiver
Certain Channels need to be "primed"
