Satmaps Malfunction? | SatelliteGuys.US
daveh505@comcast.net
104
2
Las Cruces NM
I have tried every hyperlink to Satmaps I can find and all I get are a lot of "CLICKS". It sounds like when a virus is trying to overide my virus checker/cleaner with multiple dropdowns. Everything else works fine.
Works for me with Firefox and IE I have and you need IE9.
Update both and make sure your antivirus and firewall software dont block that app it tries to load.
Running IE8 on XP SP3, and it works fine for me, pulled up a map and FCC bulletin.
Try uninstalling IE8 (revert to IE7) then re upgrade to IE8.
Are you on XP SP3?
I have a laptop with running W7 and IE8. It downloads and displays Satmaps just fine. My desktop runs XP Home Ed SP3 and IE8 will not. So it has to be the desktop setup.
How to program remote 2?
HD PPV in DVD PQ?
