satmex 5 HELP! | SatelliteGuys.US
satmex 5 HELP!
cwntln
Hi...new here.
Searching for a provider so that we can use satmex 5...WE DO NOT want to use directway....by any means. Bad experience there.
so far we have not found anyone. We are in Northern California.
We have a dish just need a provider!!!
Any help would REALLY be appreciated!!!
cwn and tln :cool:
What type dish do you have now? If it is a Direcway system pointed at Satmex 5 then you are only going to be able to use Direcway or one of their Var's. Otherwise you are going to have to change to Starband or another provider and use their equipment and be assigned to whichever Satellite they use.
it is a superdish for eithier 105 or 121 but i have no lnb and the dish is a hard plastic with a differebt arm yhan the standard . i bought it over the internet
