SatMex 5 near Seattle? Any chance to get it? | SatelliteGuys.US
dish_in_the_sky
91
Taking the SatMex Ku Americas footprint, it shows the 43 dBw contour about at the southern border of Washington state.
I'm near Seattle; extrapolating the contours suggests a 38-40 dBw signal there.
Any chance of getting a readable signal with a 36" dish and TechSat Tracker 0.3 dB LNBF? The satellite azimuth is ~172.7 deg. (geographic) and el. is 34.8 deg, which help with short rain path and low sky/terrestrial noise pickup.
Pete there is 5 Chinese channels there ITC and the OP mentioned in another thread he is looking for Chinese channels
Not picking them up here! Will scan again :)
14 channels, 6 ITC (If you count black screen)
Signal Quality 70% 36" dish and Invacom LNBF
No go with a 36" in Seattle!
I can get 2 transponders, both HughesNET, no channels scan at all. I remember the transponders I can get are 11799 at Q of 45 and 11919 at Q of 55-60. These are solid lock, the Buzz will give a good picture at Q of 25-30 on DVB signals.
Everything else is ZIP, ZILCH, NADA. 12080 is Q of 0 no matter what I do. Nudge dish, nudge arm, tweak skew, bend dish a little to max out Qual on the 11799/11919 transponders. It "ain't happening." The qual didn't even show a 1 (and the Buzz receiver will show a Qual of 1 on a weak signal.)
RATS....:( I'll probably need a 1.2m or bigger dish to get these. Not likely to happen, too many other things to do and to throw $$$ and time at.
I DO have IA 5, G3, G13 and G10 solid. My stepfather is getting the World Cup games no problem and likes CCTV4.
I have the E* birds and a few others also but no Amazonas. E*3 I have weak (probably my motor angle is very slightly off, only a problem at the very end of the arc.) No time to dial that in, my wife doesn't want me spending more time than this on it.
I think you guys are in Minnesota.
In Minn., the signal is 43 dBw; in Seattle it is ~39 dBw. This makes all the difference.
correct
but even a 43 is hard to pick up. You would need a bigger dish
Up here in Calgary.....
My experience with SatMex 5 Ku is similar to yours but I only get one HughesNet transponder at ~35% on a Pansat 2500 with a 90cm dish (My arc is acceptable but not perfect due to a slightly nonplumb mount). Excellent quality on C-band (3m dish) though,but that doesn't help you.
Amazonas Ku and Pas 9 Ku are quite strong for me so a bit of tweaking should bring them in for you.
Finding your true South in Quebec ?
Which to get
