SC 530 Box | SatelliteGuys.US
SC 530 Box
Grandpa J
397
3
Camarillo, CA
If anyone knows the answer to this question I would be very thankful.
I have a Star Choice 530 receiver which is sending an overscan picture to the TV set. (I've had the TV checked so I know it's not the TV.)
There is a video adjustment screen in the SC set-up menu. It will show a test screen and I can see some overscan as one side of the line is visible but the other side of that line is not.
While you can get to the video adjustment screen there is no instructions on screen or in the manual on how to make adjusts. Does anyone know where to find instructions on how to make the adjustments to center and/or reduce the picture size.
It was always my impression that this screen is designed to help you adjust your TV set.
That is, it sends a full-screen-sized signal, then you can use your TV adjustments to center and zoom the picture.
That's why it can't be moved by the receiver remote.
(Or, at least I couldn't figure out how do move it, either).
Aiming BEV - New York
Camping and aiming with 9242
