SC 8PSK changeover | SatelliteGuys.US
SC 8PSK changeover
Jumbo Dumbo
304
Shaw Broadcast Services is doing the changeovers on the fly starting at 1:00 pm edt so the cable companies techs can be at their headends.
Apparently some 505s are showing the 8PSK channels on the wrong channels. To correct do a soft reset (Hold power button on receiver down for 5 to 10 seconds). This will flush the channel maps and download a complete new map in 10 to 15 minutes.
Last scheduled transponder changeover is Sept 20.
My 505 wouldn't pick up either of the two 8PSK channels I receive (SRC & WGN) when I checked about 6:15PM. Did a reset and checked back about 6:45 and have been coming in since -- with, however, significantly lower Ebno values (+4.9) than I get on other channels.
This is on a 505 w/ quad LNB (75e).
For some reason I can't get WGN to come back even doing the power re-sets. Guess I'll give it another shot in the AM..I wonder if it has anything to do with WGN being in a temporary spot...of course others are getting it...
My 505 showed WGN at correct location immediately without reset. ECBN will probably go up after the transponder is balanced correctly.
I think I know why I missed WGN, my dish was out of alignment when WGN was moved to it's temporary spot and I think the STB missed getting the re-map info. It will probably come in with the next update.
DP34 Switch with Bell Expressvu
