Scan just Horizontal then Vertical? | SatelliteGuys.US
ndennis
SatelliteGuys Guru
123
Southern US
Just got my AZBox Premium HD going again (thanks to the folks on this forum).
I use another receiver to control my 10' dish.
I cannot remember how to tell the AZBox to just scan Horizontal, then scan just Vertical?
Currently it scans both and I get each channel twice/repeated.
Dennis,
If BLIND SCAN:
Set SAT NAME - desired sat
Set MIN FREQ - 11700
Set MAX FREQ - 12200
Set SCAN STEP - as desired (I generally use 3000 KHz of the default 5000 KHz)
Set MIN SR - 1000 KS/s
Set POLARITY - HOR or VERT as you desire
Otherwise, the only other method I can think of right now is to use TP SCAN and select all the H or all the V TPs that are listed.
RADAR
2 viruses detected in Azbox toolkit
Freezups On Youtube on Premium Plus
