scanning Hispasat with the Sathawk/Solomend/Openbox | SatelliteGuys.US
Jim S.
When someone asks you if you're a god, you say yes
5,799
1,546
FN11od
Why is it that the transponder at 12052 vertical shows up with a symbol rate of 27498 (close to its nominal value of 27500) and also with a symbol rate of 27636? It doesn't always show up twice on a single scan, but any two successive scans are as likely to report the opposite symbol rate as not. I get the same quality on both settings. I don't think I've ever had a variation anywhere near this wide happen on another satellite with any regularity at all.
On some TP's I can manually change the SR +/- 500 and still get a lock. I've probably blind scanned 30W at least a dozen times and haven't had your particular symptom happen on my Openbox.
Dish FORTEC STAR FC-110 elevation scale
Viewsat Ultra. Strong "S", NO "Q" on 97.0 W
