Science Channel Error 743 | SatelliteGuys.US
tcreek
SatelliteGuys Guru
125
37
North Pole, Alaska
Was watching the Science Channel (193) this morning and the Attention 743 screen popped up saying "This program is not available for viewing in your area". Can still tune to 5532 and watch it.
Any idea what happened?
Hello tcreek. Science Channel is on orbitals 110, (channel 193), 61.5 (channel 193), 77 (channel 193), 119 (channel 193 and 5532)
It is on free preview 02/04/16 to Tue 03/01/16. We can troubleshoot if you're missing orbitals. Please PM one of the DIRT team.
Do you normally get that channel or are you getting it because it is in freeview? If the latter that may be the reason, resetting your receiver may fix it. Either way likely a temporary problem.
I normally receive it. I suspect since I'm in Alaska, and they switch on the free preview for CONUS, it screwed up the map down for the Alaska feed. I bet it returns when the free preview goes away.
Reactions: Tampa8
I'm in Alaska, so I think the free preview screwed up the map down for us. I get it on 5532. I was watching it at the time it did it this morning, I think around 8 to 9 AM Alaska time.
HD Receiver using regular LNB??
Is Speed Of New Joey 2 , same or Faster then Wireless Joey
