Screw sets for superdish LNB mounting/shroud | SatelliteGuys.US
hariom
7
Hi,
I got a superdish 121 from a friend. He has given me the dish, lnbs and the shroud (casing). But there are no screws , mounts, etc.
I'm wondering if the hardware bag of screws and clips is available from dish stores. Or do I need to make runs to homedepot to guess the sizes.
HO
The Superdish is obsolete, they are no longer manufactured, and more or less no longer supported to my understanding.
Spare parts can still be had, but for how long, perhaps until the remaining inventory is depleated.
What are you going to do with this? Everything from the 121 is pretty much on the 118.7 AFAIK.
You can check with sadoun.com I'm sure he has what your looking for, but you might be better off going with a 500+ if your seeking international programming.
cable AND satelite possible?
In CS HELL!!!
