ScrewJacks on Prime Focus Question | SatelliteGuys.US
Cold Winter
82
Anyone know if these new 180/240cm dishes with polar mounts have a range of travel when used with a screwjack?
I always thought it was around 120 degrees but I can't seem to find ( or I'm just dense ) any specs on that.
Anyone know what the figures are?
ThankYou.
ThankYou.
I would think that 120 deg may be close to max range with a actuator!The range will depend on the actuator size!I have a 24" actuator and get from 20 west to 135.
Well 105 degrees of travel is pretty good too.
Are you suggesting a longer arm ( 36" actuator ? ) would travel further or is that about the limit with your 6 footer?
I would think 36 would be overkill! Most people here that use a actuator go with a 24".That should get you most or all the satellites that your 6 footer see in the sky.
false signal from signal finder?
corotor wideband
