Yes I currently have the R15 and maybe switch to the H20 but use the card from the R15.Are you sure you are using the right model numbers R15 is a DVR H20 is a HDTV non DVR?
You're going to get a card when you get the new receiver anyway... what's the benefit of reusing the old one, even if
you could?
Access cards are access cards, they just authorize programming. The one from the R15 will work in any HD receiver
Not buying new. That was why I asked the question. If I get the H20 I'll call a try to have them tag the R15 card with the H20 serial#.But my question still stands... if you're getting a new receiver, it comes with a new card, what's the point of trying to re-use one?
Limited time offer
