SD DVR Hook up Questions | SatelliteGuys.US
Duraduk
34
4
I have a Direct SD DVR that is capable of recording while watching another program.
I live in a RV with a single lnb Vu Qube antenna. I have it set up as a single DVR currently. I was told by Direct Tech that I could use a swm and hook the single antenna line into it and feed the two recvr. connections.
I picked up a Direct compatable SWM from Radio Shack (2x4) and hooked the antenna into line A and connected to tuner one and two input on the box.. The signal strenth meter showed signal reception on both tuners but when it went through set up it wouldn't work. I have 18" round antenna with SWM selected.
Any suggestions other that a two lnb antenna?
loose channels after 7 hours
"Moved" Now Fuzzy Picture On Locals Only
