SDR# Revision - Some really nice improvements | SatelliteGuys.US
spongella
1,625
1,236
Central NJ
Newest revision of SDR# now shows locations of popular bands such as shortwave, BCB, air band, marine VHF, CB etc. Very nice improvements. Looks like those with the Airspy should check the new version out. But if you have just the regular inexpensive dongle the new version is something to look into also.
Found that when you download a new version, it does not have any of your old frequencies you saved in Frequency Manager, so what I do is move my old version of SDR# to another folder, then download the new version. Then I go into the old version and copy the frequencies XML file into the directory of the new version. So far it has worked for me, otherwise would have to reenter those memories.
I like the idea of the band display, I wish more software would implement this since I'm not a fan of SDR#.
Reactions: spongella
I wish SDR play and SDR# would kiss and make up so I could get the most out of my play.
For a long time I was under the impression that SDRPlay and SDR# 1489 (the latest) would not work together at all. But last week I obtained the latest drivers from sdrplay.com and was able to get it to work with SDR#. I'm not sure what features are missing with this combination?
My favorite feature with SDR# is being able to disable 'Filter Audio' for use with DSD+. AFAIK HDSDR doesn't do that.
