Search is broken | SatelliteGuys.US
Search is broken
Not open for further replies.
kstuart
5,206
Northern California
I'm not sure if there is a problem, or if the Search is working according to spec, but it is useless if you cannot search for:
- 622 (or any other 3 digit model number)
- PIP
- FOX
- L4.01
- TV1
- UHF
etc.
Search works just fine at AVS, which is also Vbulletin (they are using an earlier V3 version).
Fixed.
We switched over a new search engine in the background and the minimum characters was set to 4 by default.
I reset it to 3 and just finished rebuilding the seach index. :)
Thanks for letting us know.
Forum Option
$845.95 for a PS/3 at your store????
