You might notice that under our logo there is a big Google Custom Search Bar.
I am doing a test to see which search is better.
For our regular search we use a search engine called Sphinx, now Sphinx is much better then the built in vBulletin search engine. We moved from the default vBulletin search engine to Sphinx about 2 years ago.
Tonight as you might have noticed there is a big Google Custom Search Bar under the logo. If you search would you please do us a favor and search with our regular search AND using this Google Search.
I am trying to see which one is better... most accurate and the fastest.
If you search and try both please let me know which one you feel is better, which gives better results...
If the Google one is better I will code it so that the search box in the navigation bar will be the new Google Custom Search one... and if you click on Advanced Search it will use the Sphinx Search.
I am doing this so that you get the best results and more easily find what you are looking for when you search here at SatelliteGuys. I will keep the Google Custom Search bar on the top for the next few days so you can test both search engines so you can help me decide which is best.
